torsdag 28 november 2024
sigge_1
Finns här någon Honda mekaniker? BF90
Gjorde i våras en fullservice på min Honda BF90 och vill i samband med detta nolla timräknaren och serviceindikatorn i instrumentet enligt Hondas instruktion.
Motorn är en BF90 2012 med serienummer BBCJ-1100xxx.
På BF90 med senare serienummer (BBCJ-1300006) och framåt tycks det vara enkelt. Men hur gör jag på min?
After periodic maintenance is performed, follow these steps to reset the hour counter.
1. Be sure to turn OFF the engine before beginning the reset procedure. Pull the emergency stop switch clip out of the emergency stop switch by pulling the emergency stop switch lanyard.
2. Put the shift lever in “F” (Forward) or “R” (Reverse).
3. Turn the ignition switch ON. Do not start the engine. The buzzer will sound once.
4. Press the emergency stop switch 5 times within 20 seconds. The buzzer will sound once indicating the hour counter is reset. Periodic maintenance is required when either the operating hours or the time since the last maintenance reaches the prescribed limit. Therefore, periodic maintenance may be required before the hour counter generates a maintenance indication. Reset the hour counter whenever maintenance is performed, whether based on the time interval or the number of operating hours.
Mvh Martin
Du har antagligen elektronisk växel och och gas iST som fodrar en annan resetprocedur
I slutet av denna tråd har du nog lösningen på ditt problem.
Lägger in infon som reference här:
I finally received the appropriate reset instructions from another forum. Hope this is helpful to anyone else with this problem. These are the correct steps and are not listed in the owner's manuals for the engine or the iST.
1. Key on
2. Shift to forward
3. Remove IST fuse from engine
4. Key off
5. Key on
6. activate kill switch at 1 sec interval until beep heard
7. Key off, reinstall fuse
8. Key on
9. Job done
Honda iST NMEA Hour Reset.pdf
Redigerad av guestsson
Stort tack för svar, hann tyvärr inte testa, båten såld.
