tisdag 11 februari 2025
Lasse-L
Nya versioner till Ozie
Nya versioner till Oziexplorer http://www.oziexplorer.com/ 12th May 2005 - New release version 3.95.4i of OziExplorer is available for download from the OziExplorer Software page. Nya versioner till Ozie Added support for Magellan Explorist USB plus some other changes. 12th May 2005 - A new development version 1.11.6f of OziExplorerCE is available for download from the OziExplorerCE Development page. 12th May 2005 - A new version 3.00 of Img2ozf is available for download from the Img2ozf page
Vers 1.12.0 är nu släppt. Kanon! Bara att ladda ner. Bra tajmat på säsongen... Fixes - Fixed the problem with automatic map changing when using ecw map images. - Fixed a problem with loading ecw images, after loading a few maps the load would eventually give problems. - Fixed the problem with elapsed time logging of a log book entry. Changes - Versions of OziExplorer are available for PDA's using WinCE version 2.0 onwards, however WinCE versions less than version 3 have some restrictions because the compilers for these versions do not have the necessary functions. -the log book does not support creation of the image. - Log Book entries now record the altitude. - Added additional options to the General Settings Configuration to change the font size of the Zoom Number and the Map Name displayed on the map. The option also gives the ability not to display these items. Jmf med dev vers 1.11.6h
OziECE är nu uppe i version 1.12.3
Mest mindre fixar av smärre problem. Tex den automatiska loggboken har fixats.
OziECE är fortfarande den bästa navprogramvaran för PocketPC att användas i båt.
Såg era inlägg, vad ska man ha för pda för att det ska funka med det programmet?
Anders
Pocket PC eller Palm funkar. Läs på OziExplorers hemsida http://www.oziexplorer.com/
