måndag 03 februari 2025
aberdeennut
Archimedes Impeller dimensions
Hi can someone tell the dimensions of the Impeller for the the Archimedes 450 please I am unable to purchase one through Tradera they will not let me register.
Many thanks in advance,
Bill...
There are two different kind of impellers on that model. If the impeller housing cover is made of aluminium, then you have the same dimensions as it is on mine Volvo Penta 550. Total diameter 70 mm, hight 22 mm and the hole is 17 mm.
The other kind of impeller housing cover is a plastic one. I don't know the dimensions of the impeller suitable for this type...
Regards,
Martin
Hi Martin many thanks for that I don't know what it is made of I just want to be ready in case I need one.
Regards,
Bill...
