aberdeennut
24 -
Allt postat av aberdeennut
Try new spark plugs and check the ignition points settings and then check for spark before you try to start, hope this helps you . Regards, aberdeennut...
Welcome my friend. aberdeennut...
Try cleaning Carb, and check floats for correct levels and they are not perished. Good luck Bill...
ARCHIMEDES PENTA 45 HP OUTBOARD SPARES OR REPAIRS Have you seen this one, ends have gone.
Yes my friend they seem to be all over the world, is it the right engine you were looking for on Ebay UK. this one is worth watching there are others on there, it is just a pity about the distance. Regards, Bill..
http://cgi.ebay.co.uk/SPARES-OR-REPAIR-VOLVO-PENTA-55-HP-OUTBOARD-MOTOR_W0QQitemZ110443517477QQcmdZViewItemQQptZUK_CarsParts_Vehicles_Boat_Engines_EngineParts_SM?hash=item19b6f25625&_trksid=p3286.c0.m14 Hi my friend there is an engine in Ebay UK at the above link please have alook and you see what you want. Regards, Bill..
Hi my friend I have just noticed your question give me some little time and I will post for you the settings If I can find them in the Manual I have. Regards, Bill..
OK my friend many thanks for your response. Kind regards, Bill..
Many thanks for that my friend, do you know of any other carburettor that would replace the bing I have a 450 and it sounds a pushes the 21 foot boat I have east but there seems to be a problem with the fuel. Regards, Bill...
Hi can any one tell me the float levei adjustment on the Archimedes 450 with the Bing carburetor, and does anyone know what the fuel to oil mixture is, and finally was it just the Bing carburetor that was used on these engines, the float level setting I have is 8mm. Many thanks in advance for any info. Regards, Bill...
Hi my friend it does sound like a fuel problem as has been mentioned , but I would strip carburetor and completely clean out and check the float level as this could be the problem, I would also check the points setting and then it should fire up. Kind regards, Bill...
HI everyone here is a link that has some info for you.. http://www.discount-marine-parts.com/ob_volvo.html
Hi stefan I would like to have one if you could oblidge. Regards, Bill....
Hi the air mixture screw on the right side as you look at carburetor, the setting is 3/4 turn...
Hi my friend this may help you, Impeller Replaces Johnson/Evinrude 775518, 375638. Fits 10 HP 1949-1957, 15/18 HP 1956-1973, 20/25 HP 1966-1978. €15,47. Kopen Informatie · impeller ... www.poortwatersport.com/buitenboord-onderdelen/johnson-evinrude-outboards/cooling...johnson.../impellers...johnson.../cat_898... - Bill...
Hi my friend it sounds more like the thermostat is sometimes opening and somtimes not. Regards, Bill...
Hi Martin many thanks for that I don't know what it is made of I just want to be ready in case I need one. Regards, Bill...
Hi can someone tell the dimensions of the Impeller for the the Archimedes 450 please I am unable to purchase one through Tradera they will not let me register. Many thanks in advance, Bill...
Hi this is for electric start, manual start is a little different, but it is only for the final adjusting. Regards, Bill.....
Yes my friend I have the VP400-A40, at present I have no means of sending it to you as I have not got a scanner as my son has bought a Mac for me and Microsoft is know good on it, keep on the site as I am preparing to get the manual put on pdf. Regards. Bill....
Hi my friend 3/4 turn is the setting 1000-1100 rpm and in neutral, final setting with mixture screw. hope this is of help to you, Regards, aberdeennut...
Hi I'm a newbie on site an anyone advise please where I can get an Impeller for the Archimedes 450, many thanks in advance. Regards, aberdeennut...
Hi my friend I am british so I hope you can translate, try the points under the flywheel three sets to adjust one for each cylinder, then it should be good. aberdeennut.
