måndag 03 februari 2025
aberdeennut
    24
Om aberdeennut
  1. Try new spark plugs and check the ignition points settings and then check for spark before you try to start, hope this helps you . Regards, aberdeennut...
  2. Try cleaning Carb, and check floats for correct levels and they are not perished. Good luck Bill...
  3. ARCHIMEDES PENTA 45 HP OUTBOARD SPARES OR REPAIRS Have you seen this one, ends have gone.
  4. Yes my friend they seem to be all over the world, is it the right engine you were looking for on Ebay UK. this one is worth watching there are others on there, it is just a pity about the distance. Regards, Bill..
  5. http://cgi.ebay.co.uk/SPARES-OR-REPAIR-VOLVO-PENTA-55-HP-OUTBOARD-MOTOR_W0QQitemZ110443517477QQcmdZViewItemQQptZUK_CarsParts_Vehicles_Boat_Engines_EngineParts_SM?hash=item19b6f25625&_trksid=p3286.c0.m14 Hi my friend there is an engine in Ebay UK at the above link please have alook and you see what you want. Regards, Bill..
  6. Hi my friend I have just noticed your question give me some little time and I will post for you the settings If I can find them in the Manual I have. Regards, Bill..
  7. OK my friend many thanks for your response. Kind regards, Bill..
  8. Many thanks for that my friend, do you know of any other carburettor that would replace the bing I have a 450 and it sounds a pushes the 21 foot boat I have east but there seems to be a problem with the fuel. Regards, Bill...
  9. Hi can any one tell me the float levei adjustment on the Archimedes 450 with the Bing carburetor, and does anyone know what the fuel to oil mixture is, and finally was it just the Bing carburetor that was used on these engines, the float level setting I have is 8mm. Many thanks in advance for any info. Regards, Bill...
  10. Yes my friend I think that would generous we all need those kind of gestures. Very Kind Kind regards, Bill..
  11. Hi my friend it does sound like a fuel problem as has been mentioned , but I would strip carburetor and completely clean out and check the float level as this could be the problem, I would also check the points setting and then it should fire up. Kind regards, Bill...
  12. HI everyone here is a link that has some info for you.. http://www.discount-marine-parts.com/ob_volvo.html
  13. Hi stefan I would like to have one if you could oblidge. Regards, Bill....
  14. Hi the air mixture screw on the right side as you look at carburetor, the setting is 3/4 turn...
