lördag 20 december 2025
torsan
    14
Allt postat av torsan
  1. Går det att ersätta Lysfotogenet medLampolja till Wallas 800 med lock? Skall ju vara renare:)
  2. Hej, går det att ersätta Lysfotogenet med Lampolja till Wallas 800 med lock? Skall ju vara renare:)
  3. Ngn som provat denna olja. Jag har en Mercury 90 hk 2 takt från 1999. Försöker vara "lite miljövänligare" så jag kör med Ok/Q8 Marina Bio TT olja, men den finns bara på 1 l och kostar nu 155.-. Hittade denna olja från Total för 139.- för 2 liter. Total är ju ett stor leverantör av oljor till biltävlingar mm så det borde väl vara bra??? NEPTUNA 2T BIO-JET Biodegradable synthetic oil for 2-stroke petrol engines of pleasure craft, outboards, jet-ski... APPLICATIONS 2-stroke petrol engines for very harsh use PERFORMANCE Classifications Conforming to the constructor's requirements  100% synthetic oil for all 2-stroke petrol engines of all capacities including for competition use  NEPTUNA 2T BIO-JET combines protection of the environment with high performance  Mixing with the fuel should be in accordance with the manufacturer's recommendations API : TC NMMA : TC-W3 ® RL- 20097F BOMBARDIER, EVINRUDE, JOHNSON, KAWASAKI, MERCURY, SEA-DOO, SUZUKI, YAMAHA... CLIENT ADVANTAGES Environment friendly Prolonged engine life Exceptional thermal resistance Easy pre-mixing CHARACTERISTICS  This oil is rapidly biodegradable in the natural environment. Conforms to local legislation requiring this type of lubricant  No exhaust smoke  Excellent lubrication at extreme temperatures  Ash-free formula: prevents clogging of ports, piston ring sticking and spark plug fouling and prolongs engine life  Exceptional anti-rust and anti-corrosion properties ensuring maximum protection of the engine internal components  Excellent miscibility with petrol enabling a uniform pre-mixing which is stable even at low temperature. May be used for in-line mixing. NEPTUNA 2T BIO-JET Units Colour - Blue Kinematic viscosity at 100°C mm2/s 8.4 Pour point °C < -39 Biodegradability % 82 The values for the data given in this table are typical values given by way of information only
  4. Hej Är det ngn som använder en stävstege till Ryds 560 Ht ? Har en 11 årig dotter som har svårt att gå och det skulle vara lättare om hon kunde ha en stege ned fram när man lägger till och det är grunt så vi slipper hiva ombord henne.
  5. Hej Har sett en Ryds 570 ? på blocket men hittar ingen sådan på Ryds sida, endast 570Dc och den ser inte alls ut så som på bilden. Den skall vara 1986 men??
  6. Lättsåld var tydeligen campingen med 50hk 4 taktaren, den försvann från blocket nyss.
  7. Ok Vad tycker du om Ryds camping 1976:a med Evinrude 89a 70 hk som ligger på Blocket. Den ser fin ut. Är en Yamaha 88 80hk bättre än en Evinrude 89.a 70hk. Båten med Evinrude ligger nämligen i rätt landsdel...... Vad jag kan se så kan man köpa begagnade motorer från mitten 80 tal för 10-15 tusen Då borde man betala max 40.000 totalt om inte båten är extra fin, fint kapell mm kanske även trailer Ryds Campingen vi var och tittade på var 56ht den lite nyare modellen med vitt skrov från 1984 och den hade ett alldeles nytt och fint kapell också dock utan fönster. Fönster är väl bra men slits kanske hårdare. Kan man köra med kapell uppe? Om man har fönster och vädret är skit ? Jätte mycket tack för alla bra och klargörande svar från proffsen på denna sida !!
  8. Hej Vad tror du om en sen 70 talare med en Yamaha 4 takt 99 (uttagen 00) 50HK Ger en 50 hk 4 takt samma prestanda som en 70 hk 2 takt från 80 talet ? 65000.- är det vettigt? Såg också en en 77:a med en 80hk Yamaha från 88 för 60000.- Har varit och tittat på den båten som var från 84 56ht som jag skrev om förut, den var fin men motorn Johnsson 70hk från 84. Dom begärde 70000 men dom var medvetna om att dom låg högt och prutmån fanns. Är 50000-55000 vettigt att bjuda? Motorn var välskött och kvitto på senaste service med slangbyte impellerbyte mm gjort i nov 06. Motorn vinterförvarat i garage och konserverad varje vinter. Senast ändrad av torsan | 22 april 2008 | 00:29
  9. Hej. Håller på och tittar efter en Ryds Camping/56Ht/560/Ht Hittade på blocket en 56HT 84:a men det står att den har 2st 20 liters trycktankar! Jag har fattat att det är en fast tank? Har du ngt bra svar? Tack på förhand Torbjörn
  10. Tyvärr hamnade dom i fel ordning, den översta är 76 an med motorn från 89 mittenbilden den billigaste båten med motor från 84(60 hk) och den sista är den nyaste båten men med motor från 84 (70hk)
  11. här kommer bilderna på båtarna jag skrev om nyss
  12. Hittade lite alternativ Ryds 56HT camping 1984 med Johnsson 70 hk 1984 = 70000 Ryds camping 1976 med Johnsson 60 HK 1984 = 42000 Ryds camping 1976 med Evinrude 70 hk 1989(uttagen 1990) 67000 Vad verkar vettigast? Lutar åt det sista alternativet. Bättre med en nyare motor än en nyare variant av båt?
  13. Hittat lite allternativ. Vad tycks
  14. Hej igen Nu hittade jag en ny ryds igen denna gång en 77a med en 90hk mercury 80-talsmotor Vad tror du om denna. Ser fin ut
  15. jättefin men det står 1982 men camping gjordes väl bara till 1979 och ersattes av 560 ht 1986?
  16. Hej Har du en Ryds camping nu? Jag funderar på en sådan. Såg idag flera på blocket. Den som såg finast ut på bild är blå och har 2 sidofönster men skall vara från 78 enligt annonsen. Kan inte stämma då? eller ? Bifogar bild
