onsdag 08 januari 2025
Skipper_85
    1
Om Skipper_85
  1. The 36.7 launched in 2002 is an development of the succeesful Beneteau 40.7 Schmicker says the 36.7 “has a more advanced hull shape and refined look when heeled at high angles.” That heeled shape, combined with what the Farr office calls a “generous rudder area,” simply means that the rudder keeps its bite in the water when the boat is reaching in big winds. “The changes are more noticeable when the boats are side by side,” says Schmicker. “The 36.7 is straighter in plan at the sheer, with less curvature than the 40.7. It has less volume above the waterline amidships because more volume was placed in the ends. The result is a longer heeled length, producing good handling throughout the heeled range. “With the keel design it’s all about laminar flow. This keel on the 36.7 is the result of years of intensive research that produces airfoils designed specifically for the boats that we design. They don’t come from the pages of a NACA foil book. They are the result of 15 years of IOR, IMS, America’s Cup, and Volvo Race research. We provide complete 3D representations to Beneteau so they can produce our designs accurately. The objective is to design the smallest rudder with the maximum lift and low drag that will withstand high loads in heavy winds without stalling. We place the rudder shaft in the blade and set the sweep of the blade tip to give the right amount of helm load for all conditions. We also want robust sections that don’t stall abruptly. Since Beneteau promotes the 36.7 as a one-design racer, it’s being produced with close scrutiny of the weight and application of raw materials. Boats are constructed to CE Class A requirements for unlimited offshore use.
