torsdag 06 mars 2025
2035
    13
Om 2035
  1. 2035
    Svänghjuls kil
    vart kan man få tag i kilen till svänhjulet på en Johnson 25hk tvåtaktare. Mvh Johannes
  2. http://65.55.72.39/att/GetAttachment.aspx?file=b539cb3e-04ba-495e-a5f2-ae6f9496f124.jpg&ct=YXBwbGljYXRpb24vb2N0ZXQtc3RyZWFt&name=aW1hZ2UtMTM0Mjc3NTM0MC1WLmpwZw_3d_3d&inline=0&rfc=0&empty=False&imgsrc=&cid=4b78e065fbcdccd6&hm__login=plutten9512&hm__domain=hotmail.com&ip=10.13.122.8&d=d254&mf=0&hm__ts=Fri, 20 Jul 2012 14:00:35 GMT&st=plutten9512&hm__ha=01_5a6d699f9a3e298db55687b2a2b2e90330ec5808bc971b5e3409b57ee48289b3&oneredir=1
  3. http://65.55.72.39/att/GetAttachment.aspx?file=b539cb3e-04ba-495e-a5f2-ae6f9496f124.jpg&ct=YXBwbGljYXRpb24vb2N0ZXQtc3RyZWFt&name=aW1hZ2UtMTM0Mjc3NTM0MC1WLmpwZw_3d_3d&inline=0&rfc=0&empty=False&imgsrc=&cid=4b78e065fbcdccd6&hm__login=plutten9512&hm__domain=hotmail.com&ip=10.13.122.8&d=d254&mf=0&hm__ts=Fri, 20 Jul 2012 14:00:35 GMT&st=plutten9512&hm__ha=01_5a6d699f9a3e298db55687b2a2b2e90330ec5808bc971b5e3409b57ee48289b3&oneredir=1
  4. http://65.55.72.39/att/GetAttachment.aspx?file=a423cd25-daf1-4d16-8255-bb18ba567216.jpg&ct=YXBwbGljYXRpb24vb2N0ZXQtc3RyZWFt&name=aW1hZ2UtMTM0Mjc3NTMyNS1WLmpwZw_3d_3d&inline=0&rfc=0&empty=False&imgsrc=&cid=4b78e065fbcdccd6&hm__login=plutten9512&hm__domain=hotmail.com&ip=10.13.122.8&d=d254&mf=0&hm__ts=Fri, 20 Jul 2012 09:35:58 GMT&st=plutten9512&hm__ha=01_9fd4e7b318c23372d5b5394aaa5018142cd565248841ba93e9ca3f99a492877e&oneredir=1
  5. Denna packningen är kass kan det vara orsaken till att den inte orkar och inte går att få nåt högt varv på mtorn?
  6. http://65.55.72.39/att/GetAttachment.aspx?file=2603fe3b-5448-4eae-8602-af4e45244911.jpg&ct=YXBwbGljYXRpb24vb2N0ZXQtc3RyZWFt&name=aW1hZ2UtMTM0Mjc3NTM0MC1WLmpwZw_3d_3d&inline=0&rfc=0&empty=False&imgsrc=&cid=4b78e065fbcdccd6&hm__login=plutten9512&hm__domain=hotmail.com&ip=10.13.122.8&d=d254&mf=0&hm__ts=Fri, 20 Jul 2012 09:13:22 GMT&st=plutten9512&hm__ha=01_072780478cfb141f32d5798d81a30d24ebb7514f57200bfbaa1a7a8458ddcb15&oneredir=1
  7. Har nu varit ute och skruvat ner det som går för att komma åt packningen. Släppte på Förgasare och sen släppte jag på alla bultar till kåpan. Men den vill ändå inte lossa. Vad mer måste jag släppa på? Kan lägga upp en bild så kanske det blir lättare att förstå?
  8. Troligen hittat felet starta motorn imorse och då upptäckte jag att den läcker vid en packning:( blir att skruva ner skiten misstänker att jag behöver en avdragare te svänghjulet. Får jag det tätt där så ska den nog gå som vanligt hoppas jag!
  9. Vad kostar en impeller ungefär?
  10. Okej tack bra tips! Kan ju prova med nya brytare och kondensator. Kanske nya tändstift? Kan det ha nåt med saken att göra? Och vad menar du med vattnet? Menar du att den kanske drar in vatten?
  11. Årsmodell 1972. Hittar inga ställskruvar konstig förgasare. Har inga manualer
  12. 2035
    Johnson 25
    Hejsan. Har lite problem med en Johnson 25hk motor.så jag tänkte höra här om någon har några bra tips och idéer. Som sagt det är en Johnson 25hästars 2cylindrig. (Tvåtakt) som är mycket svårstartad och när den väl startar så får man varva upp den rejält för att den ska hålla igång.Och när man lägger i växel så vill den gärna dö. Bra ginsta på stift nya stift bra komp. Den ryker ganska mycket tror de kan bero på att den stått länge. extremt tacksam för alla svar har skruvat på denna motorn i två veckor nu börjar få lite panik semestern snart slut å Inge åka båt har de blitt. HJÄLP!! mvh Johannes
